August 4th, 2004, 03:37 PM | #1081 |
Ok, after rendering the clip, I now have the audio! Thank you again.
August 4th, 2004, 04:15 PM | #1082 |
Thanks. Have used the first suggestion in the past and was worried that too much was lost in the conversion. Will look into the other two suggestions.
August 5th, 2004, 07:36 AM | #1083 |
Help! Someone tell me what software to get for 3D modeling!!!
Hi,
I've just bought a g5 with FCP HD and all that comes with it. For some reason, I assumed it came bundled with some type of 3D object creation and mapping software. (Well, really it does, but you have to know programming to do that in LiveType). I need to be able to create simple objects like jigsaw puzzle pieces and map them with with video footage and the like. I fiddled with Graphic Coverter, but don't think it will do quite that. Can someone suggest a good 3D graphics package that doesn't get me into Lord of the Rings type effects? Things like motion are 2 grand etc. !!!!! Right now all I need is basic object creation and mapping that I can import into FCP HD. Not sure if After FX does this (don't have it). I figured there has to be something out there under $500 bucks. I'd like to be able to do impressive 3D stuff for like industrial videos and news broadcast looking stuff. I figured that Motion would do these things . . . but unfortunately I need something this week. If common programs like Photoshop can do this, please let me know, and perhaps a bit on how to do it. Thanks! |
August 5th, 2004, 07:39 AM | #1084 |
Will do, thanks!
August 5th, 2004, 07:55 AM | #1085 |
For cheap 3D I suggest you check out Cinema4D. Alot of motion graphics folk use this for their 3D work and then combine it with programs like After Effects.
If you are doing puzzle pieces that need to explode outward or combine to create a complete image, there is a plug-in that comes with After Effects (pro) called Shatter that will do what you want. My 3D program of choice (for now) is LightWave from NewTek. Motion - when it is released from Apple - will not do 3D, rather it is a cheap compositing program that only costs $299, not 2K. As a last resort, you could always hire a freelancer to do the work for you. Cheers |
August 5th, 2004, 08:35 AM | #1086 |
Maybe it's more involved than you want, but I have been using Strata 3d on the Mac ever since 1995 or thereabouts, it's one of the oldest ones out there. Cost is a little more than what you want though, about $700. However you can download a free trial version that is fully functional for 30 days, so maybe that's a way to get your project done for nothing? http://shop.strata.com
August 5th, 2004, 10:48 AM | #1087 |
you can also take a peep at this very basic package... 3D Invigorator.
August 5th, 2004, 01:45 PM | #1088 |
xml exporting
I exported a project as xml on my G5 and would like to import it to my G4. Do I just transfer the xml file or are there other folders to transfer as well, like clips.
August 6th, 2004, 07:41 AM | #1089 |
Don't overlook Cararra Studio ( http://www.eovia.com ). This is a nice full-featured 3d animation and modeling studio with good all-around performance and features. It also runs on both MAC and PC platforms. Not "real expensive" for what you get.
August 7th, 2004, 12:00 PM | #1090 |
live MPEG-2 encoding
Soon I will be working on a project that requires numerous 1 hour sessions to be taped to miniDV, burned to DVD, and recorded to VHS. The intention is to use one continuous shot without cuts or further editing (of course, we'll see how this goes). Generally, this process will include many stages - record to miniDV, capture to computer, encode to MPEG-2, burn DVD, record VHS. I would like to make this production as efficient as possible by accomplishing as many tasks at one time as I can.
At this point, I plan to record to miniDV (camcorder), capture to iMovie (firewire), and maybe even VHS (analog out), all at once. That would knock out a lot of time, leaving only the MPEG-2 encoding stage and DVD burning. If possible, I'd like to incorporate the encoding stage into the initial record/capture. My plan would be to use a live/realtime MPEG-2 encoder (firewire or analog out) that would replace the need for iMovie. Unfortunately, I don't know much about live MPEG-2 capture and encoding or if it is even worth using for this production. Are there any low-cost (< $500), software or hardware based applications available? Is there a better, more efficient way of accomplishing this? maybe with a stand-alone dvd recorder?
Nicholi Brossia |
August 7th, 2004, 06:25 PM | #1091 |
FCP4: Cross Dissolves and Audio
In FCP4, how do you set cross dissolve to a "default" time setting, so i don't have to keep changing the time i want?
(I've been using 00:00:00;15, i belive, nice and quick) Also, in Audio Mixer, how can you change all the audio of all (or most) of your clips so you can lower or raise them to a desired level, without have to do it clip, by clip?
Sony VX-1000 G5 1.8 dual 91 Turbo MR2 |
August 7th, 2004, 11:06 PM | #1092 |
Inserting clip w/ FCP
What's the easiest option for sandwiching a clip between two clips on the timeline without overwriting the clips?
August 7th, 2004, 11:09 PM | #1093 |
Nevermind, I already figured it out - FCP beginner here...
August 7th, 2004, 11:10 PM | #1094 |
Open the Dissolve folder in the Video Transitions folder.
Copy the Cross Dissolve transition to the Favorites folder. Open the Favorites folder. Change the name of the cross dissolve copy to something you like. Double click on the Length value and change the length of the transition to :15. Put the cursor over the name of your new 15 frame cross dissolve. Hold down the control key as you click on the name. Select "Set Default Transition" from the popup. |
August 8th, 2004, 12:03 AM | #1095 |
help me please
Ok heres the deal.
I just shot a 50th birthday party on a gl2 and an xl1s. Now i am going to capture the tapes to my powerbook (final cut pro hd). so i am trying to capture from my gl2 to my computer, but when i go under the capture mode on final cut and it seems to capture fine for about 5 seconds, then it just stops, and on the lcd on the gl2 i get a pause triangle logo in the corner, it looks like the logo you get in the top right corner when you pause your tape in vcr mode, but it is reversed with the pause logo then the triangle. anyways if anyone can help me so that i can capture the tape that would be great, thank you. alex
have you ever wanted something so bad you couldent stop thinking about it? a car, a girl, a skate trick? thats what this video was to me it started as an addiction but turned into an obsession. -Adam Johnson |
