NLE Mac / Final Cut questions from 2004 - Page 113 at DVinfo.net
Final Cut Suite
Old November 28th, 2004, 09:09 PM   #1681
Live chromakey preview
Does anyone know of a cheap little app that'll apply a rough key to a live DV feed? Preferably one that'll let you play a movie behind it but I'd be very happy just with a still. It's to make it easier to line up blue/greenscreen shots.
There used to be a handy thing with the old A/V Macs where you could key out a particular color where ever it appeared on your screen. I had hoped with the big DV evolution that something similar would exist on OS X but the only solutions I can find are expensive and geared toward the meteorlogical set.
-j
Jay Silver is offline   Reply With Quote
Old November 28th, 2004, 09:56 PM   #1682
Video Toaster rules at this.
If that's out of the question you can find many used switchers on ebay for little to nuthin.
Grinner Hester is offline   Reply With Quote
Old November 29th, 2004, 12:18 PM   #1683
mpg.. where's the sound?
Hi, I'm making a promo for an artist and she asked me to include some old material from her old proomo CD. It's a mpg file. When playback the sound is there and all is well. When I import it to FCP I have to render it to playback and there's no audio track..? I tried using QT to export it to another format but QT reports that there's no audio track..
What's happening? What can I do?
Thanks.
Alfred Okocha is offline   Reply With Quote
Old November 29th, 2004, 12:21 PM   #1684
FCP can't demux a MPEG1 file... meaning, an MPEG1 file puts the video and audio together... so when you import it into FCP you only get the video. There is a free tool to break the MPEG1 into 2 files... or, if you already have the video, open the MPEG1 file in QT and export the movie as an audio file as a workaround... I think that should work.
http://www.alfanet.it/squared5/mpegstreamclip.html
Mark Sloan is offline   Reply With Quote
Old November 29th, 2004, 01:24 PM   #1685
Ha, what a life saaver program, thanks that worked beautifully!
Old November 29th, 2004, 01:47 PM   #1686
thanks Graeme - maybe I'll just get both just in case !
Kurth Bousman is offline   Reply With Quote
Old November 29th, 2004, 02:46 PM   #1687
Aspect the Horizontal and vertical at the same time and when you get close to the center apply a white border to the wipe. This simulates the white blip as it turns off.
Michael Kavanaugh is offline   Reply With Quote
Old November 30th, 2004, 10:15 AM   #1688
And where would I find that checkbox?
I dont find it anywhere in FCP HD.
greets
Tim Commeijne is offline   Reply With Quote
Old November 30th, 2004, 11:13 AM   #1689
I don't know if this is the same as what Michael is saying but using a squeeze or pinch filter and keyframing the vertical and horizontal in one move would probably be easier than what I said earlier with compositing a couple of different moves.
James Emory is offline   Reply With Quote
Old November 30th, 2004, 12:48 PM   #1690
Since I haven't upgraded to your version all I can do is tell you how it works under FCP 3. Under the FCP menu choose Audio/Video Settings and click on the capture presets tab. The currently selected one appears highlighted with a check next to it. I'm assuming this will be the 24p option in your case. Click the Edit button (if a padlock icon appears next to the preset then FCP will automatically create a copy which you can edit and re-name as desired). In the edit screen there should be an anamorphic 16:9 checkbox which you would enable.
Like I said, this is all based on the earlier version so perhaps they've changed something in FCP HD. If so then hopefully someone else will chime in on this.
Old November 30th, 2004, 01:26 PM   #1691
Thanx Boyd.
I tried this in fcp HD and I'ts the same.
Thank you verry much!
Greets Tim
Old November 30th, 2004, 08:09 PM   #1692
FCP HD rendering 24p? Please Help!
I’m switching from Vegas to FCP 4.5 HD and I’m using footage shot in 24p on a DVX100. I captured my footage using the advanced option (pulldown removed) Now when I put the footage into a 24fps sequence it wants me to render, but not if it’s in a 29.9fps sequence.
Can someone please help me understand this. If the footage is 24p and I’m using a 24fps sequence, why should I have to render before viewing?
Fred
Fred Zara is offline   Reply With Quote
Old November 30th, 2004, 10:34 PM   #1693
FX1 monitoring with apple cinema display??
is it possible to watch my fx1 in HD quality directly on my apple cinema display 20"?
and in case that its possible
what kind of cable adapters or interfaces do i need
to connect the FX1 with the apple display
thanks for help
christian
Christian Buehner is offline   Reply With Quote
Old December 1st, 2004, 06:41 AM   #1694
RED Code Chef
Welcome aboard DVInfo.net Fred!
I did a search (see the button in the upper right and the link in
my signature) in this Mac forum on 24p and the first page yielded
these threads that might help you futher on what the correct
workflow should be for 24p in FCP:
http://www.dvinfo.net/conf/showthrea...threadid=35601
http://www.dvinfo.net/conf/showthrea...threadid=35492
http://www.dvinfo.net/conf/showthrea...threadid=31712
I also did a search in this forum on "24p AND render" and got
the following threads which are more specific to your problem:
http://www.dvinfo.net/conf/showthrea...threadid=14433
http://www.dvinfo.net/conf/showthrea...threadid=14323
Rob Lohman, visuar@iname.com
Old December 1st, 2004, 07:09 AM   #1695
RED Code Chef
Christian: welcome aboard DVInfo.net! I have moved your thread
to our Mac editing forum because it is much more likely that people
in here will know what kind of inputs are on the screen and how
you could convert other signals into signals it accepts.
Good luck with your quest!
