NLE Mac / Final Cut questions from 2004 - Page 104 at DVinfo.net
Final Cut Suite
Old November 3rd, 2004, 09:15 PM   #1546
What do you mean "all of a sudden"? Was it capturing and just stopped in the middle? Can you find what it DID capture? Are you sure you have your scratch disk set to the array?
Mark Sloan is offline   Reply With Quote
Old November 4th, 2004, 07:07 AM   #1547
Warden
Moving fonts shouldn't be a problem. Have you trashed the FCP Preferences?
Jeff Donald
Carpe Diem
Old November 4th, 2004, 07:20 AM   #1548
Warden
I suspect 7mbps is too high. I rarely go over 5mbps.
Jeff Donald
Carpe Diem
Old November 4th, 2004, 07:46 AM   #1549
Jeff,
7 mbps may be too high but do you suspect it is the cause of my problem? If so, why would it effect some clpis and not others?
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old November 4th, 2004, 07:51 AM   #1550
Warden
It would be the first place to start looking. iDVD uses lower bit rates by default.
Jeff Donald
Carpe Diem
Old November 4th, 2004, 08:01 AM   #1551
alla of a sudden as in one boot up to the next.
Creted scrath disk on all 3 drives..to no avail.
will trash prefrences...allway a little scary though.
Gary Chavez is offline   Reply With Quote
Old November 4th, 2004, 08:06 AM   #1552
importing jpg file to browser
Greetings---
For some reason, my standard procedure of importing a 48K jpg file to my hard drive, and then dragging it into an appropriate browser folder in FCP, is met with an error message "error: unknown file". The jpg file is originating from a CD-R which I inserted into my OSX disc drive, then dragged to my hard drive, but rejected at the final step of bringing it into the browser. Any thoughts?
Tim Tonner is offline   Reply With Quote
Old November 4th, 2004, 09:19 AM   #1553
I'm at work now, I'll give it a try and post a response.
Old November 4th, 2004, 11:10 AM   #1554
FCP4 or HD: Zooming in without jitters
How would you make it so you can have video playing then pause and zoom in without it jittering while it zooms in?
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old November 4th, 2004, 12:27 PM   #1555
Make sure it is an actual copy of the file and not an alias. That is my first thought...
Old November 4th, 2004, 12:29 PM   #1556
motion import to Final Cut pro HD
Hi,
I was wondering if anybody could tell me how to import a motion project to final cut pro HD. Basically it is an annimated banner I need to superimpose over some DV footage playing in the background.
For some reason it doesnt work though even after the render. Could somebody kindly tell the sequence. I must be doing something stupid.
Best
Jonathan
Jonathan Noone is offline   Reply With Quote
Old November 4th, 2004, 01:03 PM   #1557
Warden
Use "Get Info" (Apple Key, "I" key) and get the size etc. How big is it?
Jeff Donald
Carpe Diem
Old November 4th, 2004, 01:59 PM   #1558
You should try out a program called Atlantis2 (http://www.dvfilm.com/atlantis/index.htm).
It is basically a program (Mac and PC) that can convert from PAL to NTSC and vice versa. I have had pretty good experiences with it. I have tried at various post houses to get the conversion done more professionally, and Atlantis2 comes pretty close at a fraction at the cost at a post house.
Thomas
Thomas
Thomas Berg Petersen is offline   Reply With Quote
Old November 4th, 2004, 04:58 PM   #1559
RED Problem Solver
Most pro production monitors support PAL and NTSC. For a deck, look at a Sony DSR-11 or DSR-25 which are both PAL and NTSC. To convert from PAL to NTSC for DVD, check out my standards conversion software at www.nattress.com which does a great job for this.
Graeme
Graeme Nattress is offline   Reply With Quote
Old November 4th, 2004, 05:00 PM   #1560
RED Problem Solver
Encode in compressor not in DVD SP 3 as it can often guess the wrong field order.
Graeme
