Audio hz rate off on FCP capture at DVinfo.net
Final Cut Suite
Old August 2nd, 2009, 03:06 PM   #1
I captured some recent footage shot with my Canon XL2 and noticed that the audio gradually went out of sync from the video on the captured clips. When I control-click on the clip and check the item properties, I noticed that the Audio rate under "format" is 48002hz (as opposed to 48Khz) and on another clip, it was 48007hz. What is happening?
Chuck Peterson is offline   Reply With Quote
Old August 2nd, 2009, 10:06 PM   #2
It's a documented firewire issue - Nothing to do with audio properties of the QuickTime.
1) Make sure tape has no timecode breaks
2) Use a deck to playbacks to capture card (best way- also can capture to pro-res)
3) Capture your tape in 25 minute chunks via firewire
-C
Christopher Drews is offline   Reply
