Gamma issues solved in The new Final Cut Studio? at DVinfo.net
Final Cut Suite
Old July 26th, 2009, 04:50 AM   #1
Images: 32
Any info on this? Haven't found anything specific just yet.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old July 26th, 2009, 05:29 AM   #2
Hi Michael
I believe issues of gamma are more deeply rooted within the current (and past) Quicktime implementations, rather than specific to Final Cut Studio. As far as I can tell, the new Studio does not install nor implement a new QuickTime engine so it seems unlikely that you'll see your concerns addressed with this particular release ... however, the consensus seems to be that the forthcoming QuickTime X framework may finally provide the best shot yet at seeing the back of such issues.
Best
Andy
Andy Mees is offline   Reply With Quote
Old August 18th, 2009, 03:30 AM   #3
Jim Jannard said all the gamma issues were fixed in Snow Leopard.
Mathieu Ghekiere is offline   Reply With Quote
Old August 22nd, 2009, 08:06 AM   #4
Sponsor: Westside AV
I got very different (darker) on exporting a sequence in FCP7, than I did exporting from 6.0.6.
I did exactly the same export as self contained Prores422 1080i 60, as I had done about two weeks ago.
Both were imported into M100. And the difference is striking, so something has changed.
This is when viewing on through a Kona HDe on a NTSC HD monitor and can easily be seen on scopes.
If someone is interested I can Post screen shots and scope shots.
