Death Race text effect at DVinfo.net
Final Cut Suite
Old July 23rd, 2009, 12:44 PM   #1
You guys seen that text effect in Death Race 2000 where the text is in the scene, but behind the foreground subject matter? How is that done? Can anyone refer me to a tutorial?
Craig Lieberman is offline   Reply With Quote
Old October 7th, 2009, 03:29 AM   #2
The other option is to do this (which I JUST figured out how to do on my own!), in Vegas
Foreground object http://img32.imageshack.us/img32/209...924heg0606.jpg
Mask http://img3.imageshack.us/img3/1003/transk.png (white is transparent actually)
Keep in mind this is example for ONE frame only. You would have to make individual car masks for every other frame (in my most recent vid I had to do this, not sure if it will be every frame in your project -- just go through frame by frame to see if the position of your object changes. If it's static, then you only need 1 mask).
Here the method is outlined
http://img23.imageshack.us/img23/9277/91596006.jpg
1st track is yellow Le Mans text.
2nd track is the mask.
3rd track is the footage
On the 2nd track, you add Mask Generator with the settings as shown. Make sure alpha is checked. Key to this is having the Text track in Parent Composite mode (by clicking the arrow that points downward, below the ! icon above it). To the left of that arrow is a green icon with an x, this needs to be on multiply.
Voila :)
Graphic/web design: http://www.jade-raven.com / Sim-racing video project: http://flsimgt.blogspot.com / @justinlself: http://www.twitter.com/justinlself
Justin Self is offline   Reply With Quote
Old October 7th, 2009, 03:27 PM   #3
Here's a interesting tutorial using the new Mocha motion tracking plug-in for After Effects. Let's see if I can explain how it works:
1) You draw a mask around a moving object (like a car)
2) Using Mocha you can track that object which will in turn adjust the shape of your mask to track the moving object (mind blowing!)
3) Then once you have the car cut out, you can easily place it into another scene, place text behind it, etc....
Here's the tutorials:
Red Giant Software: Red Giant TV - Episode 27: Building an Airport Scene - Part 1: Backplate
Red Giant Software: Red Giant TV - Episode 28: Building an Airport Scene - Part 2: Compositing
I don't have Mocha (but I'd like to!) but I understand the concept. Hope this helps! :)
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply
