Additional easy setups missing at DVinfo.net
Final Cut Suite
Old June 26th, 2009, 01:57 AM   #1
On my Mac Book Pro 17, both in Final Cut and Compressor, I only have basic easy setups available. No ProRes HQ etc. On my 8 core desktop Mac Pro, all are available. The funny thing is that all the setups are present in Additional Easy Setup folder, but are somehow not available in mentioned applications. They are simply not listed. What am I missing? Any help appreciated.
Daniel Ridicki is offline   Reply With Quote
Old June 26th, 2009, 02:09 AM   #2
You need to copy the Additional Easy Setups files from
Macintosh HD>Applications>Final Cut Pro Additional Easy Setups>English
to
Macintosh HD>Library>Application Support>Final Cut Pro System Support>Custom Settings
Old June 28th, 2009, 12:13 AM   #3
Thanks Nigel
It is great to have access to the wisdom of the guys in this forum. I am new to Mac, and still in the process of finding my ways around. Thanks!
Old June 28th, 2009, 06:34 AM   #4
Nice you resolved the issue Daniel.
& if you permited me a question to Nigel about it:
I've located: Macintosh HD>Applications>Final Cut Pro Additional Easy Setups>English
to
But, when I search:
Do not have Final Cut Pro System Suport folder but this two:
Macintosh HD>Library>Application Support>Final Cut Studio/DVD Studio Pro
and
Macintosh HD>Library>Application Support>Final Cut Studio/Motion
Where's supposed I have to copy those Additional Easy Setup files to?
Thanks in advance.
Juan Todoli is offline   Reply With Quote
Old June 28th, 2009, 08:06 AM   #5
I don't recall now whether I need to create that directory or whether it was created when FCS was installed. There should be a
Macintosh HD>Library>Application Support>Final Cut Pro System Support>Plugins which is where extra Plugins get installed
I would just go ahead & create the directory & copy the files into it.
Old June 28th, 2009, 08:27 AM   #6
Ok Nigel.
Thanks.
Old June 28th, 2009, 11:07 PM   #7
No change
Nigel, Juan,
I was a bit too fast to declare it works. It does not! And, to make it even more strange, additional setups ARE present in the folder suggested by Nigel:
Checked my son's Mac Book Pro only to discover identical problem: all easy setups listed in both folders, but not present in applications. What am I missing?
Old June 29th, 2009, 12:52 AM   #8
Please note : You are looking in the wrong Library>Application Support
It's confusing - I know. There are two Library's on every OS X system.
The problem you stated above is because you are looking in the user's Library instead of system's Library. See attached screenshot which show's both paths.
Hope this helps,
-C
Old June 29th, 2009, 03:23 AM   #9
If Finder is confusing you then open up a terminal window & enter the following line exactly (I suggest that you use cut & paste) & then hit <RETURN>
ls '/Applications/Final Cut Pro Additional Easy Setups.localized/English.localized/'
You should see a listing of the Easy Setups that you need to copy & if you enter the following it should list the ones available to confirm that you have copied to the correct directory.
ls '/Library/Application Support/Final Cut Pro System Support/Custom Settings/'
Old June 29th, 2009, 06:09 AM   #10
OK guys - it is there!!!
Thanks a lot guys. In is there and it works as supposed. Best regards.
