Out Of Sync ... at DVinfo.net
Final Cut Suite
Old June 10th, 2009, 09:35 AM   #1
Out Of Sync ...
Hello All,
I'm using a Sony Z7 (rx'ing on both card and tape) and editing on FCP. The card 'log and transfer' works without a hitch but when I start to 'log and capture' ... the playback (raw or in the timeline) show that the audio follows the picture by around 6 frames.
The settings in FCP are as follows:
Easy Setup
DV
DV-PAL Firewire basic
Video Settings
DV 48khz
Audio Settings
DV 48kHz
Why should there be such a delay in capturing from tapes? I wonder if there's something in the settings that isn't quite right.
I'm also getting a slight vertical shift ... not out of the camera but while watching the capture screen ...
Anyone had the same problems?
I look forward to hearing from you,
Stuart
Stuart McAlister is offline   Reply With Quote
Old June 14th, 2009, 12:04 AM   #2
Sounds like this could be a NTSC easy capture setup. Press Shift+Q to make sure your easy setup is indeed in PAL mode instead of NTSC.
Hope this helps,
-C
Old June 14th, 2009, 11:05 AM   #3
How are you monitoring? On your computer monitor? Or through a converter (DV firewire converter, AJA Io HD, etc... to an external monitor) If you're monitoring through a converter to an external monitor then you need to make sure your audio is going through the converter as well.
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply
