Possible to capture SD into FCP6.0.4 w/o Timecode? at DVinfo.net
Final Cut Suite
Old May 26th, 2009, 04:49 AM   #1
Hello,
I'm hoping someone here has an answer to this. Is it possible to capture footage shot SD in a Canon XLH1 into FCP 6.0.4 via a MacBook Pro? My Firewire jack seems to not be working.
I've tried to use a device called a Hollywood DV-Bridge from a company called Dazzle. FCP sees the video but won't do the capture because it doesn't see the timecode. I'm connecting to the DV-Bridge from the RCA outputs on the side of the camera.
Any advice would be greatly appreciated. I'm under a deadline to edit a project and can't capture the footage.
Also... Will SVHS transmit timecode with a+v?
Mario
Mario A. Salinas is offline   Reply With Quote
Old May 26th, 2009, 07:07 AM   #2
You could try this:
In "Audio/Video Settings" under "Device Control Preset" select "non-controllable device".
Writer-Director-DOP
www.liamhall.net
Liam Hall is offline   Reply
