Where can I find my Quicktime Pro Registration Code?
I have FCP6, but I recently had a HDD crash, so I am reinstalling all of my software. Problem is I no longer seem to have Quicktime Pro, just regular Quicktime. If I am correct, the Pro version comes with FCP6, but when I open QT it doesn't have any of the features of QT Pro, such as exporting etc. Any idea where in the packaging the registration code is? I can't find it anywhere
If you have QT PRo installed with FCS then you don't have a registration code. Check in System Preferences>QuickTime>Register In the Registration Code box there should be a light grey entry Automatic & under that box should be written QuickTime 7 Pro
My QT registration box isn't greyed out. It is asking for a registration code. I assumed that QT Pro was installed automatically when installing FCP. Maybe it was a checkbox I forgot to check in the FCP install?
The box isn't greyed out it just doesn't have a code in it but does have the Automatic in light grey italics. You cab delete the word but it's visible again once you close & re-open QT Preferences.
It's a while since I installed Final Cut but I don't recall there being an option of whether or not I wanted QT Pro. It was just there after I had finished the installation. Did you re-install from the Final Cut Studio DVDs? |
#5 |
Here is a screen grab. You can see that the only thing that is greyed out is th option for organisation. Any ideas what I can do?
#6 |
Dunno. All I can suggest is to re-install the whole lot again.
#7 | |
It's annoying - I reinstalled FCS 3 times before I found an answer |
#8 |
Better than Halle Berry
Yup- reinstall FCS. You do not need a separate REG code for QT PRO if the installation goes well.
Noah |
