Soundtrack Pro - Apply to whole track - Can you help? at DVinfo.net
Final Cut Suite
Old May 19th, 2009, 12:26 PM   #1
Hi All,
I'm working on a movie project where each track is one character's voice. The clips are made up from various takes, which means various source files.
I'd like to apply noise reduction to the entire track for each character, but I've only been able to figure out how to do it a file at a time by opening each individual file up in the wav editor (instead of multitrack) reducing the noise, saving it then going back to the multitrack editor.
Since there are a LOT of files on each track this takes forever - is there any way to apply the noise reduction to every file on a track at once?
Luke
Luke Hill is offline   Reply With Quote
Old May 19th, 2009, 02:41 PM   #2
Export Entire Track
Luke,
There might be a better way but you could try this - but you have to finish editing first. Duplicate your sequence so you don't mess anything up. Mark an in and out at the beginning and end of your sequence. Select one audio track then Export Audio to AIFF. Import that into Soundtrack pro and reduce the noise on that track. Then save it and re-import it into FCP.
Do that for each track.
Troy Teuscher is offline   Reply With Quote
Old May 21st, 2009, 01:17 PM   #3
Thanks, Troy - that'll work. I just wanted to make sure I wasn't doing something wrong.
