Sony HVR-Z7, BlackMagic Decklink Card and Final Cut Pro at DVinfo.net
Final Cut Suite
Old April 26th, 2009, 12:21 PM   #1
I am recodring a documentary on a Z7 at 1080 25p Scan (capturing progressive but recording interlaced), and I am going to edit on a MacPro which has a BlackMagic Decklink card.
Is it best to capture through the BM's component input, or just via FW400 directly from the camera?
If I capture using the BM card I can't control the camera, is there any way to control the camera via the FW400 port but capture through the BlackMagic Card?
Thanks.
Matias Baridon is offline   Reply With Quote
Old April 30th, 2009, 03:46 PM   #2
With a Z7, the easiest way to work is to put the Compact Flash Card from the camera in a CF-reader, and use Log & Transfer instead of capture in FCP.
Luc De Wandel is offline   Reply
