Not Enough Physical Memory??!?!?! at DVinfo.net
Final Cut Suite
Old March 11th, 2004, 10:39 PM   #1
Hey everyone,
I have a Dual 1.25Ghz G4 with 2GB of Ram & I get a message that says--
"The program you are tying to install requires 1024K of physical memory, which this machine does not have. Continue installing Yes or No?"
--whenever I try to install the software that came with my new Palm Tungsten E. Can anyone offer any info as to what this message means & whether or not I should ignore it?
If it's not one thing, it's another!!!
Erik Selakoff is offline   Reply With Quote
Old March 11th, 2004, 10:44 PM   #2
Warden
What are you trying to install?
Jeff Donald
Carpe Diem
Old March 11th, 2004, 10:59 PM   #3
Hey Jeff,
I'm just trying to install the software that came with my Palm Tungsten E. It's just their Dektop Installer. I don't know if this helps but after I insert the CD i'm supposed to click on the Palm Desktop Installer icon & after doing that I get the message about not enough physical memory.
Any ideas?
I called Palm & they said it was a Hardware Issue.
Old March 11th, 2004, 11:06 PM   #4
Warden
You probably have too much memory installed and it is confusing the installer. Remove some ram and try to install the app. You may have to go below 1 GB to get it to work. Once installed you can re-install the ram
Jeff Donald
Carpe Diem
Old March 11th, 2004, 11:11 PM   #5
Hey again Jeff,
Perhaps this is a dumb question but how can I have too much memory? I don't understand.
Old March 11th, 2004, 11:14 PM   #6
Warden
Some applications don't like to "see" more than 1GB of ram. They produce errors when they encounter this. This may not be the ultimate cause, but it's where I would start.
Jeff Donald
Carpe Diem
Old March 11th, 2004, 11:15 PM   #7
Ok. I'll give it a try & let you know. Thanks.
Old March 12th, 2004, 12:12 AM   #8
Hey Jeff.
Thanks alot. That seems to have done it. Now I just need to learn how to use the thing.
Cheers,
Erik
