Yea or nay burner question at DVinfo.net
Final Cut Suite
Old February 15th, 2004, 01:15 PM   #1
Did a lot of looking on this site (fantiastic info) and I just want to know if I've misunderstood.
The Pioneer DVR-A06 will work with
(imovie 3.0.3), ( idvd 3.0.1) or studio pro.
I have a brand new G4 1 gig processor, I am running OS X 10.3
If I've read the posts correctly, I believe it should be ok, buy I just want to double check as I am very new to this computer thing.
Joe
Why ask me? I thought you were in charge!
Joe Gioielli is offline   Reply With Quote
Old February 15th, 2004, 01:39 PM   #2
Hi Joe,
I recently installed a Pioneer DVR-A06 in my dual 1.25 G4 with 10.2.8 (you probably read a couple of my posts) and it works great. I've successfully burned cds and dvds with the Mac Disk Utility, Toast, and iDvd. From what I understand, any system with 10.2.6 or above can run the DVR-A06 no problem.
You may also want to try the DVR-A07. It just came out a couple weeks ago and has 8x dvd burning capabilities (A06 only has 4x). Check this thread: http://www.dvinfo.net/conf/showthrea...threadid=21142. The first post was about trouble with Windows and the burning software that comes with the drive, however other Windows users, and a few Mac users, have posted that it works great and will even burn 8x to the regular 4x dvd-r discs.
Nicholi Brossia
Nicholi Brossia is offline   Reply With Quote
Old February 15th, 2004, 01:50 PM   #3
Actually I would beware of the A07. I ended up taking it back because it kept reporting errors and refused to write the lead in and lead out on DVD+R discs. I was using Memorex 4x DVD+R discs. It wrote CDs just fine. Never tried writing to a DVD-R. I was using Toast with the burner, and Toast works with everything! I didn't try it with DVD Studio Pro because that is not how I prefer to burn the disc (it's the whole "fewer coasters" thing, kna mean?)
Ted Springer is offline   Reply With Quote
Old February 15th, 2004, 05:18 PM   #4
Warden
I only use DVD-R and have no problem burning with the AO7. I also do not try burning at 8x with 4x media.
Jeff Donald
Carpe Diem
Old February 15th, 2004, 05:56 PM   #5
It probably only has problems with DVD+R/W then. Isn't the + format supposed to have better error correcting during the burn?
Old February 15th, 2004, 06:11 PM   #6
Warden
I've heard that also. Maybe the Mac software (Toast, Disk Copy Utility etc.) doesn't fully support the increased error protection (just a guess).
Jeff Donald
Carpe Diem
Old February 15th, 2004, 07:30 PM   #7
I bought an A06 for my G4 DP 800 a few months back. From DVDSP if I click "Build and Format" using 4x Apple DVD-Rs it will freeze up during burning or finishing the disk. If I use 2x Apple DVD-R it works fine.
To my knowledge you can't specify in DVDSP what speed to burn with, So now I have to build the DVD in DVDSP, then go to Toast and drag the VideoTS and Audio TS folders to Toast 5.0 and burn the DVD-R there specifying 2x burning.
I've been told Toast 5.0 has some 4x burning issues that Toast 6 has resolved. Anyone else had these problems?
Andrew Hogan is offline   Reply With Quote
Old February 15th, 2004, 11:36 PM   #8
It might depend on the media and how compatible it is with your burner. http://www.dvdrhelp.com/forum/archive/t172496.html
One of the things the article says is that + and - media are about equal in compatibility, and that the difference in compatibility between the formats is neglible.
One recommendation for media are Ritek discs- "$1.08" each at meritline.com (never used meritline). http://www.meritline.com/hacochforrid.html That media should burn at 4X with the A05 and should be compatible with a lot of DVD players.
Glenn Chan is offline   Reply
