Changing Frame rate of a Clip at DVinfo.net
Final Cut Suite
Old February 9th, 2004, 04:12 PM   #1
Alright, I've got Final cut down pretty good, but one thing is still a mystery.
Can we knock down the frame rate of a clip? I was able to do it with Premiere and Vegas, but I'm stumped on FCP. I tried the strobe filter but the feel is not the same.
Jeff rescue me!
Best Regards,
Mark T. Monciardini
Riverlight Studios
www.riverlightstudios.com
DVX100/Final Cut Pro 4/Mac G5 Dual 1.8
Mark Monciardini is offline   Reply With Quote
Old February 9th, 2004, 05:52 PM   #2
Contributor
Hi Mark,
Do you have any more detail on what you're trying to accomplish?
HTH,
Clayton
Clayton Farr is offline   Reply With Quote
Old February 9th, 2004, 06:40 PM   #3
Thanks Clayton,
I just want to knock down to 24 (23.98)
Best Regards,
Mark T. Monciardini
Riverlight Studios
Old February 10th, 2004, 12:24 PM   #4
Joes Filters has a frame rate adjuster.Not to mention a lot of other very useful filters.
Matt Stahley is offline   Reply With Quote
Old February 20th, 2004, 01:58 AM   #5
Speaking of Joes Filters, how would you rate the quality of their filters?
Robert Paul is offline   Reply With Quote
Old February 20th, 2004, 10:29 PM   #6
I tend to use Joes Filters on every project. IMO they are excellent.
Old February 21st, 2004, 10:24 AM   #7
RED Problem Solver
IF you want to go from 29.97 to 24p, resulting in a 24p timeline you could export to a 24p quicktime, then I have the solution for you. I wrote a pair of Standards Conversion filters for FCP - www.nattress.com - and the Film Converter is expecially designed to go from NTSC to 24p. You can see the results of it on my website where I detailed the use of this technique to produce a web short "Bird Brains: The Nest Generation" - http://www.nattress.com/BirdBrains/birdBrainsWorkflow.htm
If you want to make your 60i look like 24p, but have it reside in a normal NTSC timeline, then look at my Film Effects, as that's what that was desinged for.
Graeme
Graeme Nattress is offline   Reply
