general error on capturing at DVinfo.net
Final Cut Suite
Old February 8th, 2004, 11:15 AM   #1
general errror on capturing
I am trying to capture material I captured yesterday from the same tape but I am getting a general error message, also on "capture now". I trashed the prefs and repaired permissions, I think, but to no avail...
The only difference is I installed Sapphire pluginn, tryout.
D.Slingerland
director/cameraman
http://www.slingerlandproductions.nl
David Slingerland is offline   Reply With Quote
Old February 8th, 2004, 01:36 PM   #2
I disconnected the computer and started it again but still no capture possible. I am runnning FCP 4 on panther and it was always working well but now I dont know what is wrong..
D.Slingerland
director/cameraman
Old February 8th, 2004, 03:01 PM   #3
Warden
Have you tried removing the plugin? What computer are you using, what size drives, how full are they, how much ram, what version FCP, what version OS? Anything else plugged into FireWire?
Jeff Donald
Carpe Diem
Old February 8th, 2004, 03:25 PM   #4
I deleted the project and openend a new one. This somehow solved the problem.
My system is panther, single 1.25 mac with fcp 4.0 and one gig of ram... Never had this problem before. I did remove the plugin but it had no effect on it whatsoever. Deleting the project and making a new one solved everything but I still dont know what was the problem Jeff
D.Slingerland
director/cameraman
Old February 8th, 2004, 03:29 PM   #5
The drives are big enough and are internal, 120 gig, i can still use 50 gigs. OS 10.3.2 but none of that stuff changed maybe the project somehow got corrupted?? only the canon on firewire for capture
D.Slingerland
director/cameraman
Old February 8th, 2004, 04:55 PM   #6
Warden
Here are the directions for deleting FCP preferences. You may have had some corrupt project files.
Jeff Donald
Carpe Diem
Old February 9th, 2004, 11:37 AM   #7
thanks Jeff, I have seen that piece by you before but I am wondering about repairing permissions on the STARTUP DRIVE. why? and this can only be done if you use the install cd and read from it because thats what disk utility tell's me.
D.Slingerland
director/cameraman
Old February 9th, 2004, 01:19 PM   #8
Warden
You do not need the install disk. Open Disk Utility. The default location is My Drive> Applictions>Utillities>Disk Utility. Highlight My Drive (by clicking on it's name in the left hand column once) and select repair permissions. You can only repair permissions on the start-up drive.
Jeff Donald
Carpe Diem
