DVD's wont play on all players - Page 2 at DVinfo.net
Final Cut Suite
Old June 17th, 2004, 09:56 AM   #16
Not really but it depends on your encoder, source footage etc etc. Some encoders will give you footage that looks fine at 3-4 avg. others look terrible!
Encode and see for yourself. You can always do a 3-5 mins edit of sections of your footage and run it through your encoder, Compressor, QT, BitVice etc to see what works best for this job.
Jake
Jake Russell is offline   Reply With Quote
Old June 17th, 2004, 10:02 AM   #17
Thanks. I used the built in encoder in DVDSP for the project I mentioned. Should I be using Compressor? I've also seen remarks about BitVice. This is all pretty new to me :P
Dave Cook | Panasonic PV-GS200 |
PowerMac G5 Dual 2Ghz | Final Cut Express
| DVD Studio Pro
Dave Cook is offline   Reply With Quote
Old June 17th, 2004, 10:19 AM   #18
There might be several reasons that your (recordable)dvd's don't play not just the bitrate.
Keeping it down a bit will help as will using AC-3 audio instead of PCM. Use A.Pack for that, you get it with dvdsp.
I like BitVice over Compressor still as it has DVNC for noisy footage and Compressor is still allowing illegal spikes. It's getting better all the time though.
I import my files into dvdsp so can't comment on that part of the workflow. Even if I used QT I'd export then import them as mpeg-2. I like to see what I'm dealing with and it leaves one less thing to worry about a muxing stage.
Burn at 1x also.
Jake
Old June 17th, 2004, 10:22 AM   #19
Thanks for the advice!
| DVD Studio Pro
