DVD Studio Pro questions? at DVinfo.net
Final Cut Suite
Old April 9th, 2009, 07:12 AM   #1
Hey everybody,
I am working on a project in DVD STP and I got two questions:
- I have a different font I wanna use in DVD STP but I am not able to import it. I tried dropping it in all the font lists I have on my comp and I've used the lettertypecatalogus, but it still doesn't appear in DVD STP. What am I doing wrong here?
- I have created a button to use in the program but there are only a few colors to choose from for the buttons. Why can't I select a custom color for the buttons?
I hope someone knows the answer to this. Thank you in advance
Niels
Niels Neeskens is offline   Reply With Quote
Old April 9th, 2009, 07:14 AM   #2
I forgot to say that I tried dropping another color on the button and that works, but then it stays on the button at all times. I need the button to be transparent in normal state, custom color while selected and transparent again when activated. I can't seem to find a way to do that?
Old April 10th, 2009, 04:52 AM   #3
I solved a lot of the problem, but I still need to know how to make the button and the text work at the same time, but do different things, like the picture beneath:
http://www.nieproductions.nl/pictures/Menu.jpg
Old April 10th, 2009, 11:03 AM   #4
Go Go Godzilla
Images: 15
Niels,
What you wanting to do is very easily done in DVD SP4 however explaining the process isn't so easy on a forum.
I strongly suggest you pick up a copy of the Apple Pro Training series DVD Studio Pro 4/ Ritter/Ramseier, both first and second editions. It has very easy self-paced tutorials and comes with lessons on a DVD. The courses at Lynda.com are also good but I found the book/DVD to be a better resource since it doesn't require using the internet.
Old April 10th, 2009, 02:48 PM   #5
If you're having trouble getting the new font to show up in DVD Studio Pro it could be how you're importing the font into you system. The correct way to import a font is:
1) Bring the font onto your system (could be on the desktop, portable hard drive, what ever)
2) Double-click on the font file. This will bring up a little window that shows you want the font looks like.
3) In that window click the Install Font button
In my experience, this is the best way to have a new font instantly be available to all your applications. If that doesn't work try this:
1) Launch the application Font Book
2) Find the font your having trouble with and select it from the font list
3) Choose File>Validate Font
If the font is corrupt, this check will tell you. It's actually good to validate all your fonts using this process. It can help eliminate future system errors that can crop up.
Sony EX3, Canon 5D MkII, Chrosziel Matte Box, Sachtler tripod, Steadicam Flyer, Mac Pro, Apple/Adobe software - 20 years as a local videographer/editor
Mitchell Lewis is offline   Reply With Quote
Old January 14th, 2010, 11:38 PM   #6
I'm having trouble with a font.
In Photoshop CS4 is appears as "Apple Chancery".
In DVDSP4, it does not show up in the list.
I opened "Font Book.app", found the font, and validated it.
Still no appearance in DVDSP4, although i did not restart the app.
Any thoughts?
Scott
Shot-By-Scott
Scott Brickert is offline   Reply With Quote
Old January 18th, 2010, 01:04 AM   #7
Hi Scott, looks like your issue is resolved?
Apple - Support - Discussions - Font used in Photoshop not appearing in ...
My apologies -- I haven't been here in a few months and am just now catching up here and at the Apple Support Discussion Forums.
Thought it would be beneficial for folks here to know what the eventual (successful) outcome was so we'll be in a better position to assist someone in the future with a similar question.
Dan Foster is offline   Reply With Quote
Old January 18th, 2010, 08:28 AM   #8
Yes, it pays to scroll all the way to the bottom before concluding a font is missing. Apparently DVDSP4 does not organize strictly alphabetically.
Scott
Shot-By-Scott
Old January 18th, 2010, 09:14 AM   #9
Scott
Shot-By-Scott
