Compressor doesn't work in panther... at DVinfo.net
Final Cut Suite
Old October 29th, 2003, 07:55 PM   #1
Hi,
I did an archive and install of Panther on my 10.2.8 DP 1.25ghz G4. Everything has worked fine since I upgraded, except for the fact that the "Export to compressor" is greyed out. When I try and start compressor externally it instantly quits. All my other programs work...
Do I have to reinstall FCP 4? If I had to, how would I uninstall it? Should I just delete the things in /Applications and that will be that?
thanks
Nik Hanselmann is offline   Reply With Quote
Old October 29th, 2003, 07:57 PM   #2
Warden
Make sure QuickTime is serialized for QT Pro
Jeff Donald
Carpe Diem
Old October 29th, 2003, 08:03 PM   #3
Quicktime is Pro'd
Old October 29th, 2003, 08:19 PM   #4
I fixed it!
I copied
/Library/StartupItems/Qmaster
/Library/Frameworks/Compressor.framework
/Library/Frameworks/MediaServerAPI.framework
/Library/Frameworks/Qmaster.framework
/Library/Frameworks/AECore.framework
from /Previous Systems to /Library
and everything works!
Old October 30th, 2003, 10:05 AM   #5
Thank you for the tip on this. I know a few brave souls that did the upgrade right away as well. They are not having any problems as of yet (Even though they have a FireWire Drive attached!)
I will let some people know about this if they are having this problem as well.
iThink, therefore iMac
www.emotiondv.com
DV Discussion for the rest of us
Kray Mitchell is offline   Reply With Quote
Old October 30th, 2003, 10:13 AM   #6
Warden
I noticed that on one of the Clean Installs I did the entire frameworks folder did not get copied. But that machine didn't have FCP 4 on it, so I didn't have that problem.
Jeff Donald
Carpe Diem
Old December 19th, 2003, 02:46 AM   #7
This just happened to me too ie. Compressor was "greyed out" in FCP and wouldn't launch from the Dock. I'm not sure why, perhaps because I had to recently re-install OS 10.3 again after Disk Doctor killed my Panther. Maybe newer versons of Nortons (that work) should be called "Disk Vet".
I also had just installed the FCP 4.1.1 update, Live Type update, etc. Probably I just hadn't noticed Compressor wasn't working for the past 2 weeks.
Anyway if this happens to anyone else the cure is:
just reinstall COMPRESSOR again from your backed up CDR copy of CompressorUpdate1.1.pkg
Andrew Hogan is offline   Reply
