How To : FCP preview editing result realtime on HDTV?
Hi,
I have a used 19" HD Ready TV from Samsung.I wish to use it as my Editing Monitor.BTW ,i shoot in Panny SD100. And edit on MacBook Pro. Question: How s'ld i connect the 19' monitor (HDMI? AV? RCA?) with my editing software through MacBook Pro? Thanks!!! |
To connect via HDMI, you will need something like the Matrox MXO2.
Mike Barber "I'm laughing to stop myself from screaming." |
MPS Digital Studios
I've used the MXO and MXO2, and the MXO is best for monitoring (the MXO2 is a lot like the ioHD, but you can monitor, just not with all the extra cool features the MXO has).
Welcome to Matrox heath
My Final Cut Pro X blog |
If you want to use the HDTV for broadcast-quality input/output, monitoring, and up/down/cross conversion then you will need the MX02 for use with your MBP. On the other hand if you only want to hook up an external monitor for more casual video playback then you just need a DVI-HDMI convertor lead to connect from the DVI-out of the laptop to the HDMI-in of the TV.
Cheers Nigel |
#5 |
MPS Digital Studios
Some video formats, like HDV, need a converter to be able to monitor. A capture card, the MXO devices, etc. can do that. Btw, here are the comparisons of the MXO family of products:
http://www.matrox.com/video/media/pd..._selection.pdf heath
#6 | |
Let say, i'm using MBP + Cinema Display for my workflow...then, i'll not able to use the DVI-HDMI convertor for my HDTV display anymore...am i right? so what s'ld i do? |
#7 | |
I was trying to understand whether you just want to add another display on your laptop or whether you really need all of the facilities of an MXO2 which costs almost as much as the MacBook Pro. If it's just another monitor then a something like a Kensington USB dual monitor adaptor at about $100 is all you need & should work OK with your 'HD Ready' TV Kensington - K33907US - Dual Monitor Adapter Cheers Nigel |
#8 |
Oppss...sorry, that's my fault...haaa..thanks for understanding!!!
Erm...it is a very good idea and thanks for the link, will look into it!!! May i know, Nowaday Preview via DVI is the new ERA and better playback quality? |
