NLE Mac / Final Cut questions from 2003 - Page 93 at DVinfo.net
Final Cut Suite
Old November 21st, 2003, 08:37 AM   #1381
MPS Digital Studios
Thanks.
heath
My Final Cut Pro X blog
Old November 21st, 2003, 01:40 PM   #1382
I've had no issues with Compressor's image quality, I use it to encode 24p material. I used the demo version of Bitvice (which adds a "bug" on the screen making it look like network TV) and there was all sorts of digital artifacting on the edges of the black letterbox bars (my aspect ratio was slightly wider than 16:9, thus requiring more bars). Other than that it seemed to look OK, but I'll stick with Compressor for sure.
Ted Springer is offline   Reply With Quote
Old November 22nd, 2003, 12:37 PM   #1383
TV tuners for the Mac
Does anyone use a PCI or USB tv tuner with thier macs? What do you think about it? I've been checking them out and see that some will allow for selectable quicktime codecs for TV capture. Does anyone know if you can use the QT mpeg2 codec with any of these devices?
Matt Stahley is offline   Reply With Quote
Old November 22nd, 2003, 01:35 PM   #1384
Final Cut Express & After Effects 6.0
Right now, I'm using Final Cut Express in 10.2.8. I will be upgrading to 10.3 and Final Cut Pro 4 later next year (after all the bugs get worked out and everyone is running smoothly). However, I would like to buy After Effects 6.0. Basically I'm just wondering if anyone has any experience with FCE and AE6. I know FCE doesn't have AE plug-in support, but how easy is it to go back and forth between the programs (most likely by saving as a final cut project file)? Also, have there been any bugs with AE6 running on 10.3?
I just downloaded the trial version of AE6, so I'll definately get some idea of how well these programs work together, but any extra help would be very appreciated.
Nicholi Brossia
Nicholi Brossia is offline   Reply With Quote
Old November 22nd, 2003, 05:33 PM   #1385
Automatic Duck might work for importing your whole project into AE. Not just individual clips.
The other way is to manually bounce files around by exporting reference movies from FCE and importing rendered movies back into FCE.
http://www.kenstone.net/fcp_homepage...en_fcp_ae.html
Old November 22nd, 2003, 06:10 PM   #1386
$299
Go to: http://www.formac.com/p_bin/?cid=solutions_converters_studiodvtv
Hope this helps.
Aaron Rosen is offline   Reply With Quote
Old November 23rd, 2003, 10:52 PM   #1387
multiple camera imports
Hi there. I think there are probably a few of these posts out there already, so I apologize if I am repeating one.
I'd like to get into monitoring and recording multiple camera's for shows that I will be recording. Instead of recording the show individually on the seperate cameras, then syncing it all up in FCP, I'd like to be able to import and record live from multiple cameras, or at least be able to switch between cameras live, then do my editing in FCP.
Any suggestions? I'm up for practically anything. Any hardware and/or software I might need to accomplish something like that.
Thank you,
Josh
Ye who asks a question remains a
fool for five minutes, ye who does not
ask a question remains a fool
forever.
Joshua Cohen is offline   Reply With Quote
Old November 24th, 2003, 06:47 AM   #1388
Warden
You'll need an additional piece of equipment that acts as a Special Effects Generator (wipes, fades etc.), Frame Synchronizer, and Switcher. You'll need to monitor the individual feeds to the board and switch it live, the output going to your NLE to be recorded. It may be more trouble and expense than doing it all in post with FCP. It could save a lot of time though.
Jeff Donald
Carpe Diem
Old November 24th, 2003, 06:49 AM   #1389
HAHA, you sure make it seem like that, however, if it can be done and made easy to do, in the long run, it might be easier to do it live, rather in the post.
Thank you very much
forever.
Old November 24th, 2003, 07:10 AM   #1390
RED Code Chef
You should be able to convert the footage once it is in the
computer (although the quality might not be too great). The
problem here is getting it into your computer. Another company
might be the way to go indeed.
Rob Lohman, visuar@iname.com
Old November 24th, 2003, 06:18 PM   #1391
Any video mixer would do that. In the past I've used a Videonics MX-1 but it isn't that good (lag when you hit buttons being the main concern). There's lots of old analog mixers on eBay if you're ok with taking that risk. There's also DV mixers like the Videonics MX-Pro DV (something like that).
There are some software programs that try to do the same thing as a video mixer. Live Channel Pro for Mac, a few ones for PC like Isadora. I have no idea if these work. Live Channel Pro does work but I'm not sure if it can record at full quality at the same time.
Live editing is a bit faster but more nerveracking and it takes experience to get it right. Editing live events in post is a huge pain.
Old November 24th, 2003, 06:19 PM   #1392
There's also some expenses on top of the mixer (software) like walkie talkies and cables. Remember to include those costs.
Old November 25th, 2003, 12:18 PM   #1393
Which handbook for FCP?
Does anybody have any recommendations for a handbook for FCP 4. I'm a relative novice and have only edited using Imovie so far. Thanks
Robb Bradstock is offline   Reply With Quote
Old November 25th, 2003, 12:26 PM   #1394
Moderator
So nice to meet you Robb! How is the weather in Cork? :o)
http://www.kenstone.net/fcp_homepage...lisa_fcp4.html
http://kenstone.net/fcp_homepage/fcp....html#tutorial
http://www.kenstone.net/fcp_homepage...x.html#fcp_4.0
http://www.lafcpug.org
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old November 25th, 2003, 12:43 PM   #1395
Thanks. I'll check those sites out. It's wet and windy as usual!!! Robb
