FCP Settings at DVinfo.net
Final Cut Suite
Old March 31st, 2009, 09:44 AM   #1
FCP Settings
Any advice for settings in FCP
Camera
Sony HVR-V1U
set to 30p 1080i
Recording to HDR-DR60
Importing to FCP via the HDR-DR60 (shift-apple-8 capture) Can't preview just have to load
I am doing a daily newscast at school, we only have 90 min to video, edit and have ready to play at the end of the 90 min class.
I don't have time to convert to prores or anything like that, any advice on the best settings to use. We occasionally do green screen weather stuff, so quick render times are helpful
Using a Mac Pro (last year's) and the latest FCP
Any suggestions will be greatly appreciated!
Jason
Jason Boyette is offline   Reply With Quote
Old April 1st, 2009, 01:12 PM   #2
Rendering long-GOP formats like HDV is going to take longer, so you need to make a decision as to whether you want to
A) capture in HDV and deal with long renders
B) capture in ProRes and deal with larger file sizes
C) capture in DV and work in a standard def format
If you're doing any chroma-keying work, I would likely go with B.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old April 1st, 2009, 01:15 PM   #3
The only catch with "B" is that I can't capture in prores via the HDR-DR60...unless someone knows something that I haven't figured out yet...and if there is a way...please fill me in!
I will try prores tomorrow and see how it goes (i'll record to tape and capture that way)
Old April 1st, 2009, 01:26 PM   #4
Ah, you are acquiring on a drive instead of tape. Then you would have to transcode to ProRes afterwards. Either workflow A and B has a cost in time; one at the head, the other at the tail. If this is the case then go with A but have your HDV timeline settings changed to render using ProRes. This will give you the best trade-off. I would try this before changing to a tape-based acquisition, which will add ingest time.
Mike Barber
