Giving Color to the Sky in FCP at DVinfo.net
Final Cut Suite
Old February 23rd, 2009, 01:57 PM   #1
I'm trying to put a filter on the top 1/3 of a clip to darken the sky.
Any guidance would be appreciated.
Sam Rider is offline   Reply With Quote
Old February 23rd, 2009, 04:38 PM   #2
you better will create a mask out of the sky.
convert video to B&W using histogram, you will isolate the brightest part and using some rectangular cache you will cut the bottom part of the picture.
with this mask you can apply all effects you need to the sky only.
Old February 23rd, 2009, 10:30 PM   #3
why not just drop a TGA with graduated alpha on . make in PS
for a filter you can dupe the clip to the track above,
filter it as needed
generate a matte in PS - black to white gradient, hard edged shape, whatever. save as TGA
put Make Alpha filter onto clip in FCP that you CC'd
place matte TGA into video well of filter and then select the appropriate option like LUMA to generate the matte
or
you could use Pixel Chooser in any of the BorisFX BCC filters which has built in shapes, channel mattes ( luma, alpha, invert luma, R,G B ) or still use an external matte image and do the same thing directly to the clip you need to work on. BCC pixel chooser rules for this kind of work.
or
you can use the secondaries in the 3 way color corrector to make the matte and CC
or
you can send the clip to Color
or
you can send the clip to motion to mask & CC
or
you can export the clip to AE to mask & CC, import rendered clip
or
you can dupe the clip twice above the original.
in the top most clip do whatever to turn it black and white so that you get white where you want to key, contextual menu "disable clip"
on the clip below, CC is as you need, then right click it and use composite mode ->track matte so that the middle clip uses the top as the matte
I'm sure there is at least another way to two to do this
Steve Oakley is offline   Reply With Quote
Old February 24th, 2009, 07:33 AM   #4
you're welcome to grab my gradient filter and give that a go if you like:
http://web.mac.com/andymees/Free_and...nt_Filter.html
Andy Mees is offline   Reply With Quote
Old February 24th, 2009, 09:43 AM   #5
Go Go Godzilla
Images: 15
Andy,
Super plug-in; very simple but *extremely* useful. I've been recommending it to my clients ever since you first posted this in a different thread.
Old February 26th, 2009, 07:24 AM   #6
Thanks Robert
Old February 27th, 2009, 03:42 PM   #7
Hi Andy, this looks like a handy filter. Quick, stupid question, do I just drop this filter into my FCP plug-ins folder or is there another place for it?
Thanks.
Chad Hucal is offline   Reply With Quote
Old March 1st, 2009, 09:58 PM   #8
Contrast Filter
Try Dominik Seibold's Contrast Filter.
It might be of big help for you.
P.
http://www.dominik.ws/DominiksContrast.fxplug.zip
Peter Kraft is offline   Reply
