Audio Drift Problem with STP Noise Reduction at DVinfo.net
Final Cut Suite
Old February 4th, 2009, 06:03 PM   #1
When I send an audio track to STP from FCP as an audio file project, apply noise reduction and save it, the audio and video no longer sync up. I have searched all over for a solution and have found posts on other forums from people with the only resolution being sound soap. Any help other than using sound soap would be greatly appreciated.
The FCP settings are 1080p24 and STP is set to 24fps for both project and synchronization.
Josh Laronge is offline   Reply With Quote
Old February 4th, 2009, 09:53 PM   #2
Are you changing in and out points in STP accidentally? In order to set the noise print and then the area to be affected, you need to select the waveform, not the in and out points. Only thing I can think of and I just did about 200 Send to STP for Noise Reduction on a 720P60 project.
Old February 4th, 2009, 09:59 PM   #3
Hey Shaun,
Thanks for the response. I haven't touched the in/out points and have successfully done this before. I'm wondering if it's a 24fps thing.
Old February 4th, 2009, 10:39 PM   #4
Are you Sending Only Referenced Media, the tick box in the export dialog?
Old February 5th, 2009, 08:54 AM   #5
I've tried it both ways without success.
Old February 5th, 2009, 09:37 AM   #6
Well, I'm fresh out of ideas. If you figure it out, I'd love to hear what it was and what the solution was. Good luck!
