September 8th, 2003, 06:31 PM | #16 | ||
September 8th, 2003, 06:57 PM | #17 |
<<<-- Originally posted by Nathan Gifford : Some of the Sony miniDVs will play Hi8 directly. -->>>
This had me going for awhile because I remember that the hi-8 tapes are a different shape and size than the miniDV cassettes. Then I realized that you were actually refering to "Digital 8" which can record in either digital or analog mode. Do they still make these? I don't hear much about that format anymore. Regardless, "miniDV" would not be compatible with hi-8 unless I'm very mixed up (which is always a possibility ;-) |
September 8th, 2003, 06:59 PM | #18 | |
Warden
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
September 8th, 2003, 08:03 PM | #19 |
i dont really understand what you meant
whats exactly wrong with importing via imovie and editing using fcp? |
September 8th, 2003, 08:33 PM | #20 |
iMovie uses files in the DV stream format, while FCP uses QuickTime files. If you capture in iMovie the files will need to be converted, and you will use twice the disk space.
September 9th, 2003, 06:21 AM | #21 |
Thanks all for the replies.
At this time, I am leaning to the Mac -- probably a G4 DP -- due to what appears to be ease of use, performance and stability. However, before I commit, I would like to know if there is anything on the PC side that will be almost as easy to use as FCE, and what would be a good, "middle of the road" config for the PC? Thanks again for the help. Mike |
September 9th, 2003, 05:08 PM | #22 | |
Premiere Pro is worth considering. digitalvideoediting.com gives it a glowing review. Avid is the industry standard so you get to learn the Avid interface. That won't get you jobs though. Edition has lots of real-time power and background rendering (wow) so you don't have to wait for things to render. My guess is that it isn't that great if you are learning to edit. Sorry if I made things more complicated for you, but there is a lot of great editing software out there. A good setup for the PC would be a pentium2.4ghz with hyperthreading, 1GB of RAM and plenty of hard disk space (RAM are storage are cheaper if you install it yourself and it isn't very hard- this especially applies to apple, which gouges you on RAM). Going higher than that isn't really worth it value-wise. You can go cheaper with a lesser Pentium or an AMD system. I'm not so sure that AMD systems would be good for video editing work though. If you want to encode DVDs then they are definitely slower. I'm not sure about rendering and the amount of real-time effects. Dual monitors would be very nice to have, but that depends on your budget. You can get dual monitors on a Mac too. |
