i need more render space
How do i make a larger Render area ? i have heaps of HHd space, when i open render manager, it only will hold 8 gig, how can i make that space larger. i do not want to del what in the render manager as i need the files.
Rob. www.rpbproductions.com robert@rpbproductions.com HD101/G5 Mac/4gig Ram/1TB HDD/30" Cinema Display/FCP. |
Change Render location in System Settings
Render Manager shows you how much you currently have rendered. Go to the System Settings menu (under Final Cut Pro) and set your preferred location on the Scratch Disks tab. There it should show how much space you have available.
(I never opened the Render Manager 'til you mentioned it. Found I have over 500 Gb of renders, just sitting around on my HD's. Guess it's time to do some pre-Spring cleaning. It's still winter up here.) |
