Jagged edges - FCP/Compressor/Encore - Page 2 at DVinfo.net
Final Cut Suite
Old December 25th, 2008, 07:38 AM   #16
Originally Posted by Derek Nickell View Post
I cant remember what HDV is at.
Should be the same as DV as both are 25mbps ASSUMING you've captured the media as HDV and not as an intermediate codec.
Old December 25th, 2008, 03:55 PM   #17
I just don't see why I would render it twice. When things aren't working it sounds like a good step though.
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old December 26th, 2008, 10:32 PM   #18
Images: 2
Thought so since it is recorded to MiniDV tape, just didnt want to give false info.
Derek Nickell is offline   Reply With Quote
Old December 26th, 2008, 10:34 PM   #19
Images: 2
It sounded like your stuff wasnt working. Did you try it? And you are only rendering once and transcoding once. Render the completed timeline to HDV when you export and transcode to MPEG-2 in compressor.
Old December 27th, 2008, 09:38 AM   #20
Thanks Derek. I got it to work the way you suggested and it saved the day. I still need to do some tests to try to get better quality. Now that all the deadlines are over I'll have some time to explore it.
www.LegacyHDV.com
Old December 27th, 2008, 04:26 PM   #21
Images: 2
Not a problem. I try and stick my 2c in there when I can.
