capture help at DVinfo.net
Final Cut Suite
Old December 13th, 2008, 05:57 PM   #1
capture help
Hi,
I am trying to capture a mini DV tape that was recorded on "Long Play"(90min). I am using FCP 5.1.4 and a Sony VX2100. In FCP I am using the Log and Capture method. The capture settings are firewire NTSC for device control and DV NTSC 48kHZ for the Capture/Input. When the capture is finished it says that one or more of the clips may have the video and audio out of sync and I should make sure the capture settings match the tape settings? Sure enough the audio and video are out of sync. I've never had this problem before. Someone else captured this footage on their own video camera and I am trying to put it on a DVD for them. Would anyone have any suggestions for me?????
Rick Fleming is offline   Reply With Quote
Old December 13th, 2008, 11:01 PM   #2
Check to see if the tape was recorded in 12 bit 32K .. if so, thene change your capture settings to accomodate
Victor Kellar is offline   Reply With Quote
Old December 14th, 2008, 11:50 AM   #3
How do I check what the miniDV tape audio settings are?
