I think compressor's filling up my startup disk... at DVinfo.net
Final Cut Suite
Old November 11th, 2008, 05:49 PM   #1
I'm trying to do some renders with Compressor, working with Uncompressed HD footage, set to render to my internal RAID, but it must be putting some temp files somewhere because my startup disk went from having around 100 gig's free to less than 10. Any ideas?
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old November 11th, 2008, 09:58 PM   #2
Did you render all the effects on the timeline?
Old November 11th, 2008, 10:57 PM   #3
Everything is rendered and exporting, I'm trying to convert my finished movie to an uncompressed HD movie
Old November 12th, 2008, 01:34 PM   #4
That's curious. I've never noticed the main drive behaving like that but I've never exported to uncompressed HD before. Are you getting low memory warnings?
Old November 12th, 2008, 05:09 PM   #5
Yeah, and I used disk inventory X to search my drive and i found big quicktime movie segments and trashed them... so there are definitely some temporary files getting created, now i just have to find out how to change where they go.
Old November 12th, 2008, 10:34 PM   #6
What codec is the original timeline? Have you tried exporting a QuickTime movie to an external drive and compressing that without FCP running?
Old November 17th, 2008, 11:41 AM   #7
The original codec is DVCPro HD 720p. I've edited and exported a Quicktime self contained movie to one of my media drives. I'm trying to use Compressor to up-convert it to 1080p using uncompressed. Final Cut isn't running, just compressor. The only thing stored on my startup disk in relation to this project is the FCP project file. All original footage and renders and finished exports are on a separate media drive.
Old November 17th, 2008, 12:18 PM   #8
Nate, just in case you haven't tried this:
- In Compressor, after selecting the export parameters, select your project by clicking on the icon in the "box" which will highlight the entire box
- Select Target ==> Destination ==> Other and choose where you would like the output to go
Old November 17th, 2008, 02:26 PM   #9
Images: 5
Nevermind, I didn't read his later post... my comments didn't apply.
-Ethan Cooper
Ethan Cooper is offline   Reply
