Color Correction Workflow
We recently switched to XDCAM HD and are doing away with tape and most of the ancillary equipment that goes alone with it.
Having said that, what's a good [cost effect] workflow for color correcting HD? What would be a good flat panel monitor to use? Since we will no longer have a Kona3 (SDI-HD) to feed it can we use DVI directly out of the ATI X1900? Anyone using the Sony LMD4250W 42-inch WUXGA High Grade LUMA Monitor or the Sony FWDS42H1 42inch Full HD LCD? How about the BlackMagic Intensity card? Or would I need an MXO2? Any siggestions would be greatly appreciated. |
I can't recommend any monitors off hand, but if you want to pull the signal straight from your X1900 you'll need an MXO (first one, not the second one).
-A |
The colour space is different between DVI (RGB) and "real" video (YUV) so you'll need to make sure you use an interface (like the MXO or a number of I/O cards) to get accurate colour.
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
