Best quality fcp import at DVinfo.net
Final Cut Suite
Old October 29th, 2008, 10:39 PM   #1
Im using a xh a1 shooting 24f. I just got FCP and I wanted to know which easy setup setting I should use to upload my footage to get the best and highest quality... Thanks
John Cambell is offline   Reply With Quote
Old October 30th, 2008, 02:10 AM   #2
As long as you are using Firewire the quality of your video will not change one iota from what it is on the tape as you are just doing a data transfer from the tape onto your HDDs.
-A
Andrew Kimery is offline   Reply With Quote
Old October 30th, 2008, 05:49 AM   #3
I use either hdv 24p or import as ProRes422. Make sure you create a new sequesnce in your file browser bin after changing the easy setup settings.
Good luck!
Mike Watkins
Mike Watkins is offline   Reply
