Problem switching angle in multiclips at DVinfo.net
Final Cut Suite
Old October 28th, 2008, 03:12 AM   #1
Problem switching angle in multiclips (solved)
I have a laaaaaaaaaarge project shot with two cameras that I've been editing as multiclip. Everything worked as usual, until yesterday, when I tried to switch angles in one of the cuts, I just got a "cling" from the Mac's speaker, and nothing happened. I tried collapsing and uncollapsing the clips, and nothing happened. Protecting the audio tracks, and nothing happened...
What's going wrong with that d*$%#d thing?
Wire telegraph is a kind of a very, very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Radio operates exactly the same way, but there is no cat.
David Lorente is offline   Reply With Quote
Old October 28th, 2008, 03:29 AM   #2
multiclip goes wonky if its rendered in the timeline ... make sure your multiclip is unrendered
Andy Mees is offline   Reply With Quote
Old October 28th, 2008, 05:29 AM   #3
Thank you, Andy. I have solved the problem. On the Viewer window, there are three buttons between the two timecode displays. On the central one, the line "Video + Audio" or "Video" must be checked. If not, it's impossible to change the active angle.
