V1U with FCS2 and Aliasing at DVinfo.net
Final Cut Suite
Old October 15th, 2008, 10:05 PM   #1
Hi All,
I know there is TONS of information out there on workflows for the V1U and FCS2, but I've read so much of it at this point and heard so many different points of view that I'm just at a loss now:-(
I have a project I shot on the V1U, 24p, Cinema Picture Profile.
I'm editing with FCS2 6.0.4, on a MacPro 2x3 Dual Core with 4GB memory and a HD Cinema Display.
I captured in FCS 6.0.4 with these settings:
Sequence: HDV - 1080i60
Capture: HDV
Device Control: HDV Firewire
I know from looking at my footage (which unfortunately I've already edited...don't ask my why I went ahead and did this, knowing it looked crummy) that these are the wrong settings. The quality in general is terrible, and the aliasing is absolutely HORRIBLE.
From reading this: http://www.dvinfo.net/conf/sony-hvr-...cp-6-02-a.html
It's my understanding that the proper workflow is:
24p/60i on tape: Capture to the 24p Apple Intermediate Codec or Apple ProRes 422 codec, then output to the HVR-V1 camcorder in 24p/60i mode.
So, I have two questions.
1. Will the workflow above work properly and give me footage without the aliasing?
2. Which is best, AIC or ProRes?
3. Obviously I need to re-capture. Is there a way to do a batch capture only using clips used in my current timeline, so that everything automatically matches to what I've edited with the new footage, or do I have to start over from scratch?
ANY help/advice is much appreciated.
Katie
Katie Mims is offline   Reply With Quote
Old October 16th, 2008, 12:34 PM   #2
Hi all,
Just to make sure I haven't lost my mind, I went back and looked at my footage clips in QuickTime, just to make sure I was right, but the artifacts are still there. It looks like a combination of interlacing and aliasing.
I definitely shot in 24p, NOT 24pA. No question there.
When I click through the frames, I end up with three frames that look good like this: http://farm4.static.flickr.com/3049/...6cdf5085_o.jpg
And two that look like this: http://farm4.static.flickr.com/3208/...330318ff_o.jpg
When I look at everything edited in FCS, it looks absolutely horrible. Infinitely worse than what is pictured in the photo above. I tried multiple sequence settings, and I can't seem to find anything that looks right.
Ideas? What have I done wrong somewhere along the way?
What settings do other V1U users use?
Katie
Old October 31st, 2008, 01:53 AM   #3
Hi Katie,
I also got that same flaw in some footage I edited in FCP when I converted to SD from HDV captured in apple Inter. codec. Everything looked fine in editing. But the rendered file looks like yours.
I would like to know if you have already resolved your issue and what you ended up doing.
Jeff
Jeff Turkali is offline   Reply
