VHS Tracking/Noise Plugin Or Technique at DVinfo.net
Final Cut Suite
Old October 13th, 2008, 10:53 AM   #1
hello. i have a client asking for a certain effect to make a video look on and damaged. this is the bit they told me to look at (1:40 in):
YouTube - Videograms of a Revolution
does anyone have any suggestions for FCP plugins or techniques that may do this? thanks!
Jon Downs is offline   Reply With Quote
Old October 13th, 2008, 11:19 AM   #2
so it appears that a "Bad TV" plugin was added to FCP6...and i'm on FCP5. does anyone know if there is anyway to get the "Bad TV" plugin in FCP5?
Old October 13th, 2008, 11:26 AM   #3
NATTRESS filters?
Old October 13th, 2008, 11:27 AM   #4
NATTRESS filters? Sorry forgot the links
Nattress: G Head Clog
Nattress: G TV Lines
Old October 13th, 2008, 12:15 PM   #5
thanks for the reply (love your plugins, i use them all the time).
but i'm looking for more of a "bad VHS tracking" type of thing...
Old October 13th, 2008, 03:10 PM   #6
Sorry they are not mine they are the work of Greame Nattress, try e-mailing him he may have an idea of how to do this for you.
Old October 13th, 2008, 08:37 PM   #7
Try the analog method. Record onto a VHS. Play it back with bad tracking onto DV or directly into FCP.
Old October 14th, 2008, 08:05 AM   #8
that's a good idea, but unfortunately, i have to sync up the "bad tracking freakouts" to an audio cue...so i couldn't use an actual VCR.
Old October 14th, 2008, 03:53 PM   #9
Do it twice. Once with good tracking, once with bad. Edit the bad tracking on cue.
Old October 14th, 2008, 07:33 PM   #10
...that's a great idea. thanks!
Old October 15th, 2008, 04:17 AM   #11
Images: 1
Can you even get VHS units with tracking control? Seems all the later ones had auto tracking adjustment and took the manual knob away from the end user.
-gb-
Old October 15th, 2008, 09:45 AM   #12
Good point. Many newer VHS decks have the tracking hidden in the remote. Some of the decks I have need to have the automatic tracking turned off in the menu before you can adjust the tracking on your own.
William Hohauser is offline   Reply
