What's Faster In Rendering? at DVinfo.net
Final Cut Suite
Old October 3rd, 2008, 09:13 PM   #1
Here's my basic question:
Does it actually shorten the export time of a clip off the timeline if you have gone ahead and rendered it out (on the FCP 5 timeline)
I have a ton of recently imported clips that I need to make color corrections and other adjustments to which causes, of course, the timeline to indicate I need to render. So I've been rendering. However, what I am not sure of is "is that rendering actually making the time required to export the clip any shorter?" Would I be better off simply exporting from the timeline without rendering?
Thanks!!!!!
Steve Crow is offline   Reply With Quote
Old October 4th, 2008, 07:41 PM   #2
The short answer to your question is yes, it takes less time to export if your timeline is fully rendered. I've always made sure I render before I export.
Ken Civian is offline   Reply
