DVD Studio Pro error at DVinfo.net
Final Cut Suite
Old October 1st, 2008, 12:57 AM   #1
Hey everybody,
I hope someone of you can help me, because I am working on a project that has to be finished today and I run into a problem. I finished my project and wanted to burn it on a DVD. The project contains menu, sub menu's, sideshows and links to movie files. It is almost 4,3 gig together so quiet big.
Now when I burn it this error pops up:
communicatieve uitingen van der noordt,Payrolling Van Der Noordt.pdf:Marker position in movie not at GOP boundary
The strange thing is that I took the pdf out of the project and it still gives this error. Anyone knows what's going on? Thanks in advance.
Cheers Niels
Niels Neeskens is offline   Reply With Quote
Old October 1st, 2008, 05:44 AM   #2
Here's the only thing I can suggest... When you create projects in DVDSP the program makes a folder called MPEG, either in the same place you saved the project file, or where-ever the assets you've imported are stored. Close the program and delete this file, open you project back up and try again... It's a long shot, but it might help.
You could also try doing a safe boot and repair disk permissions. Just restart the computer holding the shift key until you get to the gray screen with the apple logo and the spinning gear thing.
Good luck Niels!
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old October 1st, 2008, 06:47 AM   #3
Thanks a lot Nate for your help! I solved the problem. The thing was that there were still some marks left in the slideshows at the place where I deleted some stuff. When I deletes these marks and burned the project again, it worked.
I am a happy camper :)
Thanks again.
Cheers Niels
