Final Cut moving clip problem at DVinfo.net
Final Cut Suite
Old September 25th, 2008, 05:46 PM   #1
Using Tiger and QuickTime 7.5 I am experiencing a problem with clips in Final Cut not running smooth after moving from one project to another.
Method of moving clips could be the problem so let me explain. With clips in one project timeline I copy and paste the clips to another time line in a different project. In the original project the clips run smooth in the project with the copied clips it is jumpy. Both projects are the same sequence settings.
The reason for moving the clips is I have say 20 projects I am using clips from in one job.
Could this be due to QuickTime 7.5 and Tiger?
Thoughts?
Paul Cronin
www.paulcroninstudios.com
Old September 26th, 2008, 09:06 AM   #2
No input?
Is anyone running QuickTime 7.5.5 with OS X 10.4.11 successfully?
Paul Cronin
Old September 26th, 2008, 09:21 AM   #3
I'm running tiger with the latest quicktime without a problem.
Old September 26th, 2008, 09:27 AM   #4
Peter using the current version of FC 6.0.4? If yes can you cut and paste clips from one project to another and have them run smooth? Thanks this would be a great help if you could check this out for me since I have some clips that needs to go out today.
Paul Cronin
Old September 26th, 2008, 11:24 AM   #5
Contributor
That configuration works fine for me.
Old September 26th, 2008, 11:46 AM   #6
Thanks Bill
Paul Cronin
Paul Cronin is offline   Reply
