A RGB-Contrast-Plugin - Page 3 at DVinfo.net
Final Cut Suite
Old April 13th, 2009, 09:32 PM   #31
Hi Phillip,
Originally Posted by Phillip Palacios View Post
was very excited about this seeing the effects on my monitors, but when I render the filter out, FC crash...
OS 10.5.x
Fcs2
8-core mp
Just worked through this snag myself. I've been using the contrast plugin for a while and all of the sudden I couldn't render without a crash. I figured out it was because I was trying to render in 10bit mode. Changed it to 8bit and rendered. I'd love to see this filter work with 10bit...
Joel Peregrine is offline   Reply With Quote
Old April 14th, 2009, 01:38 PM   #32
Works a treat, thank you most kindly! / Battle Vaughan/miamiherald.com video team
Old June 27th, 2009, 06:20 AM   #33
Hi!
I fixed the bug, which caused the crashing (it was a problem with 32bit-pixels. FCP converts 10bit-pixels to 32bit floating point). Also I build an installer-package, because it seems that people have a lot of trouble with manually copying the plugin into the right directory.
Here's the current release:
http://www.dominik.ws/dc.dmg
The installer will automatically install it into /Library/Plug-Ins/FxPlug.
Dominik Seibold is offline   Reply With Quote
Old June 27th, 2009, 11:14 AM   #34
Go Go Godzilla
Images: 15
Puzzle Page
Dominik,
What's with the puzzle-page you created at your website home-page? I don't think I've ever seen anything like this before, being able to randomly move around web-based objects. Is it just for fun or is there a hidden action? Whatever it is, I like it.
Just curious.
Old June 27th, 2009, 01:26 PM   #35
Originally Posted by Dominik Seibold View Post
Hi!
Requires 10.5
Old June 27th, 2009, 10:24 PM   #36
Thank you!!
This is by far my most-used filter. If I WB correctly this filter is all I need to tweak the look.
Hi!
Old June 28th, 2009, 06:46 AM   #37
It is just for fun. ;)
Originally Posted by David W. Jones View Post
Requires 10.5
Yes.
