hdv 30p footage glitches during transitions
Hey everyone, this problem has been driving me nuts the last two days and I don't know why it's happening. Here are the shoot specs:
camera: canon xh-a1 fps: 30p duration: 90 seconds When exporting using Quicktime Conversion (video is for the web) I use h.264, high quality, 29.97 fps, I get a nice sized file, beautiful quality. However, 3 different times in the video my footage jumps/skips, then it jumps again a couple seconds later to correct itself. I have a small clip to show you what I mean, but I cannot host it anywhere, I can e-mail it. Does anyone know what might be causing this? It seems to only happen around when I use a transition effect. This hasn't happened before and I've tried half a dozen different ways to correct it but nothing is working. Thanks very much, Christian |
Sorry, I don't know. That happened to me to day though when I used a quicktime with "animation" codec in final cut. The video skipped at a transition, in the timeline and the export. Is your problem in the timeline, or only in the exported video?
If you don't see it in the timeline, then try exporting it as pro res, or just export a self contained quicktime. If you can get a high quality export done then you will have a final QT master that can be converted properly. |
Yea I only see it in the timeline. Is it better to do Export: Compressor, or export a non-referenced quicktime file?
