Capturing HDV and Rendering Problem at DVinfo.net
Final Cut Suite
Old September 2nd, 2008, 01:56 PM   #1
I am using FCP 5.1.4 and a Sony FX1 Camcorder. Evidently I have screwed up some settings because now I run into a minor issue with being forced to render all video when clips are placed into a sequence.
Whenever I drag a captured clip into a sequence it requires rendering. I didn't used to have to do this so am wondering what settings I got screwed up along the way.
Rickey Brillantes is offline   Reply With Quote
Old September 2nd, 2008, 04:17 PM   #2
Images: 32
Perhaps your project and/or sequence settings do not match your footage? Can sometimes happen if your mixing DV and HDV together in Final Cut Pro.
Check here to see if your project/sequence settings match your footage:
1. Sequence > Settings
2. Final Cut Pro > Easy Setup
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old September 3rd, 2008, 12:16 PM   #3
Problem solve! You're right the timeline sequence doe'snt match imported footage, Thanks Michael. I love this forum....muuuuah!!!
