downsize 1280x720 50fps h264 to SD 720x576 25fps dv pal in FCP 5.0 at DVinfo.net
Final Cut Suite
Old August 20th, 2008, 03:42 AM   #1
Hi I have a vx 2000 and I want to know how I can downsize this 1280x720 footy and load it my SD timeline.
thx advance
chef
p.s. take a look at my blog Framedblog
check out my new upcoming project FRAMED Video | Trailer low
Sony VX2K Nizo S800
Alex Anzalone is offline   Reply With Quote
Old August 21st, 2008, 08:44 AM   #2
thanks 4 helping
you guys are awesome!!!
Sony VX2K Nizo S800
Old August 21st, 2008, 09:09 AM   #3
Just try exporting it from quicktime, as a quicktime movie. Change it to DV PAL... once you see the options it should be self explanatory. You probably want it progressive as opposed to interlaced.
Aric Mannion is offline   Reply With Quote
Old August 21st, 2008, 10:59 AM   #4
yeah i alrady did that but didnt work i think the hd footage is in native 16:9 with film bars
Sony VX2K Nizo S800
Old August 21st, 2008, 04:45 PM   #5
So you want the 16:9 hi def footage to become 4:3 CROPPED footage? If so:
-Nest the HD sequence into an SD sequence
-With the SD sequence active, in the canvas, enable image AND wireframe mode via the drop down menu
-Use the image size drop down to ensure the image is smaller than the grey "workspace"
-Find a corner handle and drag the image size (the nested sequence) until it fills the 4:3 frame and pan if necessary for framing
-Render
Old August 23rd, 2008, 04:20 AM   #6
thx dude it works..!!!
Framedblog
Sony VX2K Nizo S800
Old August 24th, 2008, 12:54 AM   #7
I heard it gives not the same result as a real 50i or 60i original image?
A colleague therefore captures with a Decklink card outputting the Component from a JVC-HD200 to get the real result, as he doesn't find a proper workflow at the moment on the Mac.
Marc Colemont - Belgium - http://www.mc-productions.be
JVC GY-HM850's, HM890, HM600
Marc Colemont is offline   Reply
