Logos: what program? at DVinfo.net
Final Cut Suite
Old July 30th, 2008, 11:35 AM   #1
Hi,
I have a customer who wants his logo on the upper right part of the screen. He keeps sending me logos, which are oval shaped but are set in a square white background.
Does anyone here know what program and how to make the white clear so it can look better over the video footage?
Any help is greatly appreciated.
Chris Westerstrom is offline   Reply With Quote
Old July 30th, 2008, 11:39 AM   #2
Photoshop would work
Charlie Gillespie is offline   Reply With Quote
Old July 30th, 2008, 11:45 AM   #3
thanks, I appreciate the reply. Unfortunately, I don't have photoshop. Do you know of any mac programs that work or if any of the Final Cut Studio applications can do it?
Also, what is it called when you make a backdrop clear?
thanks
Old July 30th, 2008, 12:29 PM   #4
Kino-Eye
If the client can send you the logo so the background is a unique color that does not appear in the logo itself, then you can set that color as the "transparency" color and superimpose the logo over the video, no Photoshop required.
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye }
David Tamés is offline   Reply With Quote
Old July 30th, 2008, 01:01 PM   #5
I assume the original logo doesn't have the white square. The problem probably is that he is sending it to you as a JPG file, which doesn't support transparency. PNG, GIF, and PSD do, and they can be imported directly into FCP while retaining the transparency.
Edward Carlson is offline   Reply With Quote
Old July 30th, 2008, 01:15 PM   #6
If it is an oval shape the simplest immediate solution is to apply a "Mask Shape" (from the Matte subfolder of effects) and select "oval" in the filter settings. Then just adjust the horizontal and vertical scale to create your oval cutout. If necessary you can then soften the edge with a "Mask Feather."
Alpha channel aka matte or mask.
Tim Dashwood
Old July 30th, 2008, 04:03 PM   #7
thanks for the help everyone!
The files sent to me were .tif and .pdf versions.
I went ahead and used the quick fix that Mr. Dashwood recommended for me. It worked good enough for this project but the other tips were well appreciated for future reference!
One thing I notice, however, is the scanlines on the text (impact). Is it just to de-interlace in this scenario?
Old July 30th, 2008, 06:19 PM   #8
I believe .tif might have an alpha channel...aside from Tim's suggestion you could use the luma key
Stephen Smith
Stephen David Smith is offline   Reply With Quote
Old July 30th, 2008, 10:30 PM   #9
"gimp" is a free program downloadable that is very similar to photoshop. I have it on my PC but haven't tried it on the Mac since I have photoshop on it already.
Works great for quickly dropping out backgrounds, resizing. It recognizes and creates photoshop files as well.
Don Ward is offline   Reply With Quote
Old July 31st, 2008, 03:19 AM   #10
Aye - I use 'gimpshop' which I guess is Gimp with a more photoshop front end. Cracking little free program, although I really should invest in the mighty photoshop.
Give gimpshop a whirl - it works fine on the mac.
David Scattergood is offline   Reply With Quote
Old July 31st, 2008, 08:02 AM   #11
Better than Halle Berry
totally time to invest- you cannot really do serious DVDSP authoring without photoshop.
Noah
Noah Kadner is offline   Reply With Quote
Old July 31st, 2008, 03:50 PM   #12
I'm just wrapping up a corporate video today where the client provided a number of images which he made using "Gimp". Very impressive. Further down the line I'd like to pick up the Adobe Creative Suite, but short-term I might check out GIMPshop. Thanks for the info, David.
David Knaggs is offline   Reply
