Final Cut 6 White Balance adjust at DVinfo.net
Final Cut Suite
Old July 14th, 2008, 11:49 AM   #1
Is there a way to change the white balance of a clip in Final Cut? I know I can go to color correction and do it that way but I was wondering if there is a White Balance adjustment?
Paul Cronin
www.paulcroninstudios.com
Old July 15th, 2008, 05:28 AM   #2
Better than Halle Berry
Not really- the best way to go is use CC. But it's designed around that sort of workflow. Here's a podcast that shows how to do it:
http://www.shirtlessapprentice.com/p...l-cut-pro.html
-Noah
Noah Kadner is offline   Reply With Quote
Old July 15th, 2008, 08:01 AM   #3
Thanks Noah that is what I am doing with CC. I guess there is no way to change the clip to say 3500K from 5600K with out CC in the three way CC.
Paul Cronin
Old July 15th, 2008, 08:27 AM   #4
If there was it would be a blunt instrument- I don't think I've ever filmed in an environment where the light was all one color temperature, or matched the camera's presets perfectly.
It's easy enough to map white & gray in the 3-way CC using the eyedropper tool.
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old July 15th, 2008, 08:38 AM   #5
I agree Benjamin and it is easy to correct with CC. Just always looking for all the options.
Paul Cronin
Paul Cronin is offline   Reply
