Apple Color- Vignette issues at DVinfo.net
Final Cut Suite
Old July 12th, 2008, 09:37 PM   #1
My vignette node in the color fx room has seemed to go haywire. I can't het the invert button to work in the parameters tab. I can achieve the result if I exchange the output of the vignette between source 1 and 2 of the alpha blend node. Just can get the invert button to work.
Has anyone else experienced this?
Any help appreciated.
Mike Watkins
Mike Watkins is offline   Reply With Quote
Old September 16th, 2008, 10:50 PM   #2
I'm experiencing the same problem. I don't know what I'm doing wrong. I put the vignette on, put it through alpha blend, and then alpha > output. But what's even more bizarre, is when I click on the Output node, it remains unchanged! No bypass checked!
Zack Helmintoller is offline   Reply
