Imac 3.0 and Graid2 (2tb) at DVinfo.net
Final Cut Suite
Old July 8th, 2008, 09:00 PM   #1
I am looking at purchasing the new IMac 3.0 and a Graid2 (2tb) external FW800 drive. What are your thoughts. I do mostly SD and a little HD work right now. I know that in a couple of years I will want to go full HD and the FW800 is a limitation, but the wife wants an Ipod Touch and they are offering a free Ipod touch with a new IMAC ;-)
I do multicam editing of live events with anywhere from 2 to 4 camera angles.
1) Do you see this as feasible on this system?
2) Is there a better external solution that will provide faster drive times?
3) Should I just wait for a macpro and upset the wife?
Thanks for you input.
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old July 8th, 2008, 11:43 PM   #2
If you plan to graduate to full HD, may I suggest holding out for a Mac Pro. Not only for the horsepower, but also for the expandability. You can't stick a Kona or BlackMagic card in an iMac, for instance.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old July 9th, 2008, 05:28 AM   #3
As Mike said, when you have the budget to go for an iMac 3.0 ghz, it would be wise to save up a bit more and go for a Mac Pro.
It's a better workhorse, has better components, is less prone to faults, more expandible and faster. It's the better investment in the long run.
Mathieu Ghekiere is offline   Reply
