Gain equivalent in FCP6 at DVinfo.net
Final Cut Suite
Old June 1st, 2008, 07:44 AM   #1
Hi:
I recorded a show with fixed gain of +6dB, but it needs boost another two stops or +6dB. Is there a filter in FCP6 equivalent to gain? I have tried fiddling with brightness and contrast but the result is horrible.
Thanks, Erik
Erik Norgaard is offline   Reply With Quote
Old June 1st, 2008, 08:00 AM   #2
Proc Amp, Levels and Gamma are all going to help you correct your footage (Effects > Video Filters > Image Control) ... as are the aptly named Color Correctors (Effects > Video Filters > Color Correction)
obviously the extent to which you can push the footage depends on the quality and format of the original ... for example, well shot footage from a RED Digital Cinema camera can be pushed to incredible extremes, but if you shot in less than ideal circumstances using a low quality and/or heavily compressed format then there will be technical limits to how much correction it will take without falling apart
Andy Mees is offline   Reply With Quote
Old June 2nd, 2008, 02:33 PM   #3
When I'm correcting "lighting" of video clips, I use the 3 way colour corrector exclusively in FCP.
