going between systems at DVinfo.net
Final Cut Suite
Old May 21st, 2008, 05:04 PM   #1
I am looking to get a used mac with FCP, is there an easy way to transfer files between FCP on a Mac to adobe on a PC? how would i compress the video to switch between systems if necessary? Is it worth it?
Molly Ryan is offline   Reply With Quote
Old May 21st, 2008, 06:41 PM   #2
If you are trying to go to After Effects 7.0 or CS3 from FCP then you could use Automatic Duck's Pro Import AE 4.0
Doug Okamoto is offline   Reply With Quote
Old May 22nd, 2008, 02:42 PM   #3
how would i go about that?
Old May 23rd, 2008, 12:00 AM   #4
Hi Molly,
You can look here http://www.automaticduck.com/products/piae/ and get all the information you need on Pro Import AE.
It costs $495.
