FCP/Compressor to Sony DVD Architect at DVinfo.net
Final Cut Suite
Old May 21st, 2008, 02:17 PM   #1
I'm currently using Sony Vegas as my editing/authoring software, but we are slowly moving towards FCS. I have someone editing for me in FC right now, but I will be building the DVD's in DVD Architect. I exported the movie from FC to Compressor and used one of the DVD settings. It created an .m2v and .ac3 file that I tried to import into DVDA, but no luck. What would be the most compatible codec to use during this transition?
Chad Dyle is offline   Reply With Quote
Old May 21st, 2008, 10:03 PM   #2
I had to do a FCP to Architect DV NTSC project just last week. What I did was render out a DV quicktime file from FCP. Then transferred to the PC. Threw the file on a Vegas timeline and rendered it out to one of the DVD presets.
So basically, I used Vegas as the compressor. Work like a charm.
If you are going back and forth between a mac and PC, I recommend investing in a program called macdrive, it will make your life a whole lot simpler.
http://twitter.com/tedmcneil
Theodore McNeil is offline   Reply With Quote
Old May 22nd, 2008, 05:56 AM   #3
Theodore,
I rendered it out using Compressor as a DV Anamorphic .mov. I haven't had a chance to look at it yet, but I hope it works out. I've never used anything other than a DVD ready .mpg or .m2v file in DVDA. Why wouldn't the .m2v file that Compressor created work in DVDA?
Old May 22nd, 2008, 07:19 AM   #4
Someone else could give you a better answer, but it's basically a codec issue. DVDA doesn't support M2V.
Old May 22nd, 2008, 06:43 PM   #5
I think I need some more help here. I tried to export it out in the DV format, as well as H.264, but still no luck. Any other thoughts?
