High Precision YUV and Magic Bullet at DVinfo.net
Final Cut Suite
Old May 12th, 2008, 12:59 PM   #1
Hello, I'm having trouble trying to render my timeline in high precision yuv (in sequence settings) with the magic bullet plugin applied. Out of all my plugins, even magic bullet misfire, magic bullet looks is the only plugin that will give me this error message when trying to do a timeline render or final rende (THE EFFECT "LOOKS" FAILED TO RENDER. YOUR HARDWARE CANNOT RENDER AT THE REQUESTED SIZE AND DEPTH).
Now i know the obvious tells me that my hardware isnt up to the render but for some reason i believe there is a work-around which will still allow me to edit in high precision YUV and use magic bullet, this is very important to me as im grading a film which requires heavy colour manipulation. Heres the specs of what im working with to give you a better understanding:
FCP 6.3
1080P EX1 timeline
sequene settings to high precison yuv
graphics card: ati radeon hd2600 256 mb
4 gig ram
quad core machine
Any ideas people?
Daniel Alexander is offline   Reply With Quote
Old November 19th, 2009, 04:44 AM   #2
Hi Daniel
Had the same problem and did some research. Apparently this is caused if you have a dual screen - software bug. Unplug your second monitor restart FCP before final render and it should work. It does for me.
Solution found here:
Magic Bullet Looks- Failed To render- Hardware - DVXuser.com -- The online community for filmmaking
Hope this helps albeit a bit late. :-)
Pavel
The fish is the last to know the water.
Pavel Tomanec is offline   Reply
