FCP effects at DVinfo.net
Final Cut Suite
Old May 12th, 2008, 11:35 AM   #1
FCP effects
I have someone doing some editing work for me in FCP and then emailing the project file back. She tried to send me some effects that she had created, but when I open them, it starts Quicktime. The effects seem to have a .mov extension. Any clue as to what is going on here? I'm very new to FCP.
Chad
Chad Dyle is offline   Reply With Quote
Old May 12th, 2008, 12:07 PM   #2
Sounds like there might be a disconnect between what you need, and what your editing partner is sending you. The short answer is:
If you need a project file, it should end in .fcp
If you need a video file, it should end in .mov
...but there are probably some additional variables that are not being accounted for here. But this is a start.
Hope this helps,
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old May 12th, 2008, 12:47 PM   #3
There's two ways the video can be exported from FCP. Export>Quicktime (with self contained checked) Or export>quicktime conversion, I'm pretty sure conversion will always compress it, and that you'd always want to export quicktime (without the "conversion") Just make sure the settings in the timeline are high/Dynamic (found under RT in the top left of the timeline).
You can open that uncompressed FCP file in Quicktime as well as Final Cut. Don't use the "conversion", unless you want to make the file size smaller or something.
Last edited by Aric Mannion; May 12th, 2008 at 12:48 PM. Reason: Just re-read your post, I guess it's the project you want not the exported video. She can just send the project file.
Aric Mannion is offline   Reply
